- 30 Aug 2007
I can't remember when buying another bit of hardware seemed so difficult
I've been looking for a new monitor for photo editing / games
A good starting point seemed to be an IPS panel screen such as the Dell U2412 or Asus PA248Q.
But then I start reading about Pulse Wave Modulation (PWM) in screen backlighting and I'm not sure if it effects me. I try to find out if my current old screen (Dell 2007FP) had people complaining about flicker and the answer seems to be: some people did. So am I not effected by flicker or is my old monitor just 'a good one'?
Ok, so how about not buying a screen that uses PWM backlight dimming? Well, the Dell 2413 doesn't (the thorough TFT Central review tested it) but I'm then reading about 'overshoot'? A good example of it on U2413 youtube -
Hmm, that 'shadow' wouldn't be ok for me.
Aha, but the Asus PA248Q has a setting to control the 'overdrive' called 'Trace Free' - sounds like a good idea? Ah, but the PA248Q uses PWM backlight dimming control (again thanks to the TFT Central review) so what about it's more expensive brother, the PA249Q? Well, it's wide gamut so I'd probably feel even more need to buy a proper calibration tool. On inspection however, it seems like the PA249Q doesn't have the 'trace control' setting?
So I've even been looking as far as the Eizo EV2436W, it's 'flicker free' but doesn't have a HDMI port. Not essential, but for that sort of money I'd like the extra flexibility...
I've read so many reviews and people posting on forums about problems, difficulty getting some companies to return monitors with dead pixels, glittering anti-glare coating, backlight bleed, IPS 'glow' etc. that I really don't know if I can order any of the monitors I've seen with confidence.
I'd add that everyone on the OC forums has been very helpful, I'm just tearing my hair out over the choices
If someone could release a 1920x1200 16:10 IPS screen with flicker-free backlighting, 'overdrive' control, 1:1 mode & HDMI port for around £300-350 now would be a good time
Thanks for reading
Thanks for reading
). I can't even spot it in the BenQ store?
