Please correct me here (I'm sure to make mistakes!)
I have an IC7-MAX3 with a P4 3.0HT (prescot I think) I have decent air & watercooling in place, so I'm finally ready to increase my overclocking!
Obviously, I've locked the PCI and AGP bus and I want to leave the CPU / RAM ratio at 1:1
I hope to raise my FSB to about 250 / 260 ish (depending on how stable it remains) but I need some quality memory to do this (just using bog standard crucial stuff at the moment).
I heard that AMD CPUs are highly dependant on low latency RAM to provide a very quick system. Apparently it's not so critical on a P4?
Should I forget about CAS 2 memory and just go for some DDR4200 (533MHz) - so at least I know the memory will cope with the higher FSB?
Please let me know if I've got the wrong end of the stick here!
Thanks in advance - Toff.
I hope to raise my FSB to about 250 / 260 ish (depending on how stable it remains) but I need some quality memory to do this (just using bog standard crucial stuff at the moment).I heard that AMD CPUs are highly dependant on low latency RAM to provide a very quick system. Apparently it's not so critical on a P4?
