Is CPU Z/AI Suite giveing me false readings? (Q9650)
23 May 2004
Hello,
I have just updated my Bios on my Striker II Formula to 1401 (from 1101) My CPU is a quad 9650 (3GHz)
Well, I rebooted, all seemed ok, but when I loaded up CPU Z (V 1.46) it told me (as it is doing now), that my processor is running at 2Ghz (Multiplier: x6, Bus speed:333, FSB 1333. Also when I start up “Asus AI Suite”, it gives me the same readings (volts are 1.072 on cpu z – so they are low I guess)
However when I rebooted, I saw in the bios, that my CPU was Running at 3Ghz, and the multiplier at x9 (what it should be), and other settings as they were before update, so all seems to suggest in the bios that my cpu is running normally at 3Ghz. I did a F5 on the bios also (reset), and CPU was 3Ghz, but once again, only 2Ghz in CPU Z, and AI suite etc.
Well, I did a Crysis test, and got my usual score of 59-60 FPS, so just wondering which reading is correct:confused:
BTW, i sometimes see "x9" multiplier, and "3Ghz" in both Cpu z and ai suite, but then goes back. "My Computer/System properties give a reading of "CPU X9650 @3Ghz 3Ghz, 2.00 GB of Ram".
Cheers
~Ant
Yep, it reduces your multiplier to 6 when idle to save energy, soon as you start running programmes the multiplier goes upto 9.
If you wish you can disable this by EIST & C1E in the BIOS.
Rob
Thanks for reply
Well, just ran a 2006 mark as well, and got 15,846 (CPU score 4905), seems a bit down from my 16,800 ish i normally get with my SLI's GTX8800's (everything at stock), so may disable this as you say.
Just wondering if, while running a benchmark like 3dmark 06 (it's a CPU bench afterall:) that the "idle-save-energy" takes a while to "kick in-out" - hence the low scores here.
~Ant
No, it takes 1 clock tick, and has negligable effects on performance. It also saves power, and reduces the cpu temperatures when the cpu is under light load.
