- 29 Aug 2010
- Cornwall
So a little while back I finally built my Maximus X Hero + 8700k system that had been sitting untouched for "a while".
So I'm now thinking I should delid it to improve the temperatures so I can run with higher VCore (seems quite possible I'll need to add a bit more VCore yet).
But I don't have any liquid metal style thermal paste and I'm a bit nervous about using it anyway. I'm a bit nervous about delidding full stop.
Is it even worth delidding if I'm just going to use MX-4 under the IHS?
Watched a few videos, did an overclock, got to 4.8GHz with less than 1.3v but could get 4.9GHz stable and couldn't push voltage much higher because of temperatures.
Then a couple days ago we had a powercut (PC was off) and when I turned the PC on it had lost all the BIOS setting (I replaced the BIOS batter a few months ago, not long after I built it).
Now I had saved a profile so I just reloaded that. But when I ran Cinebench R15 (R23 doesn't work on that PC) it crashed about halfway through. The profile had the VCore set to 1.265v and I've had to bump it to 1.28v to get it stable in Cinebench. I'm not sure if I'd previous set it to 1.28v and not saved it to the profile or if I'd previously been running at 1.265v. I tried running Prime95 with no AVX stuff and it fairly quickly got to 93ºC and then the PC froze. I'm sure I was able to run all this without issue when I first did the overclock. Maybe it was 1.28v but with colder weather at the time it ran a bit cooler? I can't think why it would've run with 1.265v before but not now.
