is gigbit on a 300mbps wireless router worth it?
Caporegime
13 Jan 2010
Llaneirwg
looking to replace a temporay router now and dont want to spend the earth
the only high bandwidth stuff will be streaming HD content from router to laptop
N is rated at 300mbps at 5GHz but i am well aware of this not being able to reach this. Is then gigabit worth it or not?
where is the bottleneck?
I think you're confusing wired and wireless. Gigabit would relate to a wired connection with the router either directly or via a switch and possibly a network wall socket. This would also depend on cabling used and Gigabit capable NIC's in the wired devices.
sorry, reading it back i didnt make it clear
i will have a wired connection from server to router that is gigabit capable
im wondering if 10/100 at the router end is enough (wired) to saturate 300mbps N (wireless)..
or.. where is the bottle neck in 10/100 wired->300 N wireless? Is wireless N faster than 10/100 in real world use?
I think you need Gigabit throughout to get Gigabit so the 10/100 at the router would be the weakest link if you were connecting via cable to one of those ports. Wireless N I would say should out perform the fast ethernet connection, (quality of wireless signal permitting). The quicker the router can tx/rx with a device the sooner it can communicate up/down the Gigabit connection with the server but I think it would only achieve the rate in which it could deliver these packets to the PC.
Quite often the real world speed of Wireless N will be slower than a 100Mb wired connection depending on number of clients, other access points nearby etc. I'd still prefer to have a gigabit port on it though for when Wireless N is able to go faster.
Sounds good, im finding it very difficult to find a true dual band 2.4 and 5ghz gigabit router for a decent price.
TP-Link and Billion do some pretty fair wireless kit in the lower price brackets. This might meet your needs:
http://www.bestrouter.co.uk/routers/tp-link-tl-wr2543nd-review
Good luck
PR
had a look at that, its one of those which can only use 2.4 or 5ghz, there are a lot like that and its pointless for me as there is more than one g device in the house.
I might have to compromise and just go for single band at one time
so many decent cable routers but not adsl
If there are cable routers available that meet your wireless needs you could get one and just use it as a wireless access point (and switch if you want). Leave your existing router to do everything else. Not as neat as a single device, but it'll work okay.
good point, in that case i wouldnt need a wireless signal at all.
I think that would be the best solution, all true dual band routers are well over £60
in that case i would just bee looking for a reliable router that lends itself well to port forwarding for access to the server off site, QoS etc
