Is GPUz lying to me?
4 Jul 2008
London
Last night i did a custom vantage run, did 3 loops with extreme settings.
Checked my temps after, one gpu maxed out at around 89c, the other was 248c :eek:
That can't be right, the gpu's are close together, but never seen a difference that big!
is ur graphics card now in a puddle inside the case? xP im thinking a dodgy sensor, have u got any other gpu temp monitoring programs like rivatuner etc etc?
@ Pwndiret
Nope, but i would have hoped some kind of safety measures would have kicked in before hand :p
And hold on, i joined two months before you, and you've got over 900 more posts than me!
too much lurking methinks!
@Saaso, got everest, i'll see what that is saying
@Ghost, i should hope so
Faulty sensor - no hardware can run at 248c. It would have lunched itself well before then. The two cards will be broadly similar in temperature... top one might be a bit warmer.
