Is GT85 PTFE Lubricant spray electrically conductive?
25 Sep 2009
Darwen
I know a strange one.
I was stripping my 3D printer to blow out all the dust using canned air, I picked up the wrong can without looking and sprayed it into the Power Supply.
I tried calling GT85 but no one picked up. I looked at the Material Safety Sheet and Conductivity is "Not Determined".
Is it electrically conductive?
https://gt85.co.uk/gt85-original/
It's not a simple yes/no answer. Anything is conductive given enough voltage.
I'd say leave it to dry and it'll probably be fine.
Should be fine, use it on some of my three phase stuff and not had a issue
from the way he worded it, it was through an orifice onto unknown (surface mount?) electronics, otherwise he would have detailed components spray hit - so maybe a bit more sensitive/delicate ?
I would potentially cleanup with ipa and cotton buds
I've done stuff like this before and my general modus operandi is to turn on and cross fingers. There's no way I'm waiting for hours to see if I've buggered it up, cursing comes afterwards wishing that had indeed been the approach taken.
Helps when it's not your own stuff.
Not used that one but I use a very similar one for my 3D printers (well only used it on one the other is too new to need it) and never had an issue.
what ! gt85 is one step away from wd40 I would not put it on my bike chain,
someone gave me a can and I have just used some for a squeeky door hinge, but it is probably good for removiing glue residue too.
The Teflon (PTFE) stuff is fine for lubrication.
EDIT: Although for a bike chain I'd imagine it wouldn't last anything like as long as a specialised product and require more frequent application to keep things running smoothly.
Technically thats not true, given a high enough voltage it will cause dielectric breakdown in an insulator but thats not the same as being conductive.
