Specs:
Q6600 (I believe) @ 2.4Ghz
4GB OCZ DDR2 @ 800Mhz
An old mATX Gigabyte motherboard (can't give you the exact product, until I've had a look on the motherboard for it's name).
EVGA GTX 480 1.5GB
OCZ 700W
Recently my brother's upgraded his GPU and PSU, however the graphics card is really under performing, with usage only hitting around 85% (if you're pushing the graphics card, with high in-game settings) and only 65% with lower settings. I'm pretty sure the CPU is bottlenecking it, as I read that when you lower the settings, more work is given to the CPU. To further this, in BF3 he could play on Ultra and get 30 - 40fps, high and get 45fps, medium, 45fps etc...
If you think the CPU (and the ram, motherboard etc) is bottlenecking it, what's the cheapest CPU, ram and motherboard to buy that would be able to remove this bottleneck? He doesn't mind going second hand, so the member's market is an option should anything suitably cheap appears.
EVGA GTX 480 1.5GB
OCZ 700W
