Is it a good build ? Advice needed
13 Nov 2012
Welling
You could look at the MSI Z87-G45 motherboard, which will save you £25. You could save quite a bit on the case, too, unless you're particularly enamoured with the 540.
Really though, if you're not building for a couple of months you'd be better advised to wait to see what happens in the GPU market when AMD release their new range.
