Hi All,
I built my own machine a while back and it WAS really good, that was until I tried to play GTA 5 on it - lol
I was looking at my options to upgrade the graphics card (Its going to a 42" TV) and it appears the PCI-E2 is obsolete, so it's a new board, which is a new CPU and possibly new memory.... or is it?
I have posted my specs down below and would appreciate any recommendations ie. what can be salvaged etc.
Also, if it is new mobo, cpu etc. then I will be looking at something that will handle 1080p at 60fps, maybe 4k if it is worth getting it to "Future proof"
I am wanting to build a good gaming machine, ATM it's fine, gets 7.1 windows experience score but the graphics is really bad. ATM it crashes on a 3dmark test and sometimes it fails to boot (1 beep followed by 6) - I suspect the GPU is nackered.
Thanks in advance.
Thanks in advance.
Operating System System Model
Windows 7 Professional (x64) Service Pack 1 (build 7601)
Install Language: English (United States)
System Locale: English (United Kingdom)
Installed: 08/02/2015 19:38:05
Boot Mode: BIOS (Secure Boot not supported) Enclosure Type: Desktop
Processor a Main Circuit Board b
2.80 gigahertz Intel Core i7 860
64 kilobyte primary memory cache
256 kilobyte secondary memory cache
8192 kilobyte tertiary memory cache
64-bit ready
Multi-core (4 total)
Hyper-threaded (8 total) Board: ASRock P55 Pro/USB3
Bus Clock: 133 megahertz
BIOS: American Megatrends Inc. P1.50 01/18/2011
Drives Memory Modules c,d
1370.18 Gigabytes Usable Hard Drive Capacity
1085.90 Gigabytes Hard Drive Free Space
HL-DT-ST BDDVDRW GBC-H20L ATA Device [Optical drive]
TSSTcorp CDDVDW SH-222BB ATA Device [Optical drive]
OCZ-AGILITY3 [Hard drive] (120.03 GB) -- drive 0, s/n OCZ-4M7YMUI5O9WCXWHD, rev 2.22, SMART Status: Healthy
WDC WD10EADS-65L5B1 [Hard drive] (1000.20 GB) -- drive 2, s/n WD-WCAU48867045, rev 01.01A01, SMART Status: Healthy
WDC WD2500BEVT-22A23T0 [Hard drive] (250.06 GB) -- drive 1, s/n WD-WX81A3004546, rev 01.01A01, SMART Status: Healthy 16376 Megabytes Usable Installed Memory
Slot 'DIMM0' has 4096 MB (serial number SerNum00)
Slot 'DIMM1' has 4096 MB (serial number SerNum01)
Slot 'DIMM2' has 4096 MB (serial number SerNum02)
Slot 'DIMM3' has 4096 MB (serial number SerNum03)
Local Drive Volumes
c: (NTFS on drive 0) * 119.93 GB 21.05 GB free
d: (NTFS on drive 1) 250.06 GB 216.47 GB free
f: (NTFS on drive 2) 685.63 GB 620.63 GB free
i: (NTFS on drive 2) 314.57 GB 227.76 GB free
* Operating System is installed on c:
Network Drives
None discovered
Users (mouse over user name for details) Printers
local user accounts last logon
Trubster 13/04/2015 21:49:19 (admin)
postgres 13/04/2015 21:49:09
local system accounts
Administrator 21/11/2010 03:47:20 (admin)
Guest 08/04/2015 12:53:04
HomeGroupUser$ never
DISABLED Marks a disabled account; LOCKED OUT Marks a locked account
CutePDF Writer on CPW2:
Lexmark X364dn on USB001
Microsoft Shared Fax Driver on SHRFAX:
Microsoft XPS Document Writer on XPSPort:
Send to Microsoft OneNote 15 Driver on nul:
Controllers Display
ATA Channel 0 [Controller] (3x)
ATA Channel 1 [Controller] (3x)
Intel(R) 5 Series/3400 Series Chipset Family 2 port Serial ATA Storage Controller - 3B26
Intel(R) 5 Series/3400 Series Chipset Family 4 port Serial ATA Storage Controller - 3B20
Standard Dual Channel PCI IDE Controller AMD Radeon HD 6800 Series [Display adapter]
SAMSUNG [Monitor] (40.2"vis, November 2010)
Bus Adapters Multimedia
Fresco Logic xHCI (USB3) Controller FL1000 Series
Fresco Logic xHCI (USB3) Controller FL1100 Series (2x)
Fresco Logic xHCI (USB3) Root Hub (3x)
Standard Enhanced PCI to USB Host Controller (2x) AMD High Definition Audio Device
Virus Protection [Back to Top] Group Policies
AVG Internet Security 2015
None discovered
Communications Other Devices
Microsoft ISATAP Adapter
↑ Realtek PCIe GBE Family Controller
primary Auto IP Address: 192.168.1.9 / 24
Gateway: 192.168.1.1
Dhcp Server: 192.168.1.1
Physical Address: 00:25:22:65:39:2C
Connection Speed: 1 Gbps
↓ TAP-Windows Adapter V9
Status: Cable unplugged
Dhcp Server: none responded
Physical Address: 00:FF:34:3D:BB:68
Connection Speed: 10 Mbps
Teredo Tunneling Pseudo-Interface
↑ VMware Virtual Ethernet Adapter for VMnet1
IP Address: 192.168.49.1 / 24
Physical Address: 00:50:56:C0:00:01
Connection Speed: 100 Mbps
↑ VMware Virtual Ethernet Adapter for VMnet8
IP Address: 192.168.32.1 / 24
Physical Address: 00:50:56:C0:00:08
Networking Dns Server: 192.168.1.1
HID-compliant consumer control device
HID-compliant device (6x)
USB Input Device (5x)
USB Input Device (Logitech Download Assistant)
Lexmark X264/X363/X364
HID Keyboard Device
HID-compliant mouse
Smart card filter driver
Microsoft Usbccid Smartcard Reader (WUDF)
Fresco Logic xHCI (USB3) Hub (2x)
Generic USB Hub (2x)
USB Composite Device (2x)
USB Printing Support
USB Root Hub (2x)
Generic volume shadow copy
Xbox 360 Controller for Windows
USB Storage Use in past 30 Days (mouse over last used for details) Hosted Virtual Machines (mouse over name for details)
Last Used
Mass Storage Device, s/n 125C20100726 03/04/2015 22:23:56*
* Possibly used again before the reboot following this time.
Name Last Used
Windows 7 x64 13/04/2015 02:05:33
64-bit ready
Local Drive Volumes
Network Drives
None discovered
Controllers Display
None discovered
HID Keyboard Device
HID-compliant mouse
USB Root Hub (2x)
Last Used
Name Last Used
Gaming.
