- 5 Nov 2024
- Oxfordshire
Hello,
I see a lot of illustrated pictures of builds when looking at cases and even customer builds more specifically small for factor types where they have put fans on the bottom of the case that has barely millimetres of gap and while ive done that before, there was actually a lot bigger of a gap.
Dont know if anyone is familiar with the IONZ KZ X1 Portable, but ive been trying different ways to build my system as its quite compact and i didnt realise at first that you could fit fans on the bottom, however in my scenario with my particular a520m board, the gpu slot is closer to the edge, so any fan even slim ones gives an almost no gap(but dont touch). I am currently using a twin fan rx 570 powercolor, but i plan to use various cards.
There will be no benefit to use them as exhausts, so it would be exhaust gpu to intake case fans. How bad would it be to run it like that?. More so if i use just one fan that would cover majority of the rear gpu fan, but still sticks out to blow a little air more in to the case. 120mm fan options only.
