Is it good Enough? ... Seasonic PX80 Platinum
11 Dec 2012
Bangor - Northern Ireland
My basket at OcUK:
Total: £190.49 (includes delivery: £10.50)​
Doing an AM5 Build
X670E MSI Carbon Wifi
4x M.2 SSDS (2 x 1TB 1 x 500GB WB SN850 Gen 4 Drive ... Will eventually Add a 500-1TB Gen 5 PCIE or a 4th Gen 4)
78003XD
9 x Unifan Infinitys
360mm AIO - Eventually will go full WC Loop with same fans and D5 Pump
32-64GB DDR5 6000Mhz
6700xt (Sapphire Nitro) - Will Eventually upgrade to 7900XTX
So my Question is is my PSU future proof enough?
Just for clarity, are you saying: "Is my current PSU sufficient for this", or "should I buy this"? I ask because you have that PSU in your signature and if so, I definitely would just try it because it should be fine.
