- 31 May 2009
Troubleshoot a problem with Adobe Flash Player
Adobe Flash Player has stopped working properly on 18 occasions.
Running in windows 7, I have virtually no issues with my PC, but occasionally on web browsing when closing a tab it'll report an error, and attempt to search for a solution.
Each time the issue appears to be some function of flash not stopping properly or not working correctly when browser tabs are closed.
No within problem reporting I can see this has happened 18 times. Windows solution is browse to adboe and uninstall flash player, and reinstall flash player. This doesn't appear to make any difference.
It is always just the single browser tab which has the issues other remain unaffected.
It doesn't overly annoy me as I am usually closing tabs when it occurs, but I am wondering if others get similar issues. So do you? Anyone found a solution?
