I purchased a second hand motherboard from Ebay Gigabyte GA-EX58-UD4P
Connected it all up correctly. My monitor only has DVI and VGA ports, so went DVI from the graphics card MSI TwinFrozr3 GTX-660 2GB to DVI on the monitor.
The Motherboard powered up correctly but I was getting no signal on the Monitor. I did the usual checks, but still no signal
I decided to swap out the graphics card for an older style card that I have, this card has VGA, so this time I went VGA from the Graphics Card to VGA on the monitor, this time I did get a signal to the monitor.
I'm wondering if the DVI cable is the issue here, or my 700W power supply is not giving out enough power. 700W should be plenty for this?
I just purchased a bi-directional HDMI to DVI cable to see if this will fix the issue for the MSI TwinFrozr3 GTX-660 2GB that I want to use.
