I just put together a kids PC with a neat budget of £140 using used parts.
E6600 ~£36
4GB DDR2 667mhz [waiting to receive] ~£33
MS-7336 [OEM mobo for HP PCs, hope I don't have any issues because there is no support for this what so ever] ~£34
Case + 500w PSU ~£27
DVD-RW ~£12
160gb hard drive - donor
akasa CPU cooler - donor
Now, I've put everything together, however I haven't received the RAM yet, and I'm itching to fire the thing up and see if everything is working.
As the topic says, would it be ok to insert my 800mhz ddr2 rams into this mobo which takes 667mhz ddr2 rams
Or will I risk exploding it?
I'd like to use it today at least to install windows, and test to see if the rig works.
E6600 ~£36
DVD-RW ~£12
