I’m getting an electrician to run some Ethernet cables around my house when he rewires it. He’s strongly suggesting that I use shielded Ethernet cable as it will cross over with the electrical cables at some points. He’s also saying there is no need to ground it. I was interested to know if there were any disadvantages of leaving shielded cable ungrounded, or if there was anything I needed to worry about?
I guess I could look at grounding the cables but I’m a bit overwhelmed by it all - as hoping to only use a basic switch, and from this run some cables to wireless access points using POE and a couple of sockets in the walls in bedrooms.
