A bit of a strange question this.  My PSU has 4 rails dedicated for GPU's...say 12V5,6,7,8.  And each gpu modular connector on my psu corresponds to 1 of said rails.  Each of the 4 pci-e cables I have has a 6pin and 6+2pin on it. So when running a GTX480 for instance you only need 1 cable  and therefore it would seem you just use 1 rail.
Now here is my question. I've just bought a silverstone PP04 short cable adaptor kit to make things neater. It also comes supplied with 4 pci-e cables. Each one only has a 6+2pin connector. So to power a GTX480, I would need to use 2 cables. For instance, I would plug the 6+2pin into the modular connector on the PSU for 12V5, and the 6pin cable into 12V6. Is it safe to spread the load for a single GPU across 2 rails. I would obviously be doing the same for the 2nd gpu.
Also, I was looking at the NZXT individually prepbraided pci-e cables too. The NZXT 8pin cable is in fact just a 6pin male extension to 6+2pin female convertor. I was hoping it was a 6+2pin male to 6+2pin female. So I was wondering if it safe to plug the 6pin male end of this NZXT cable into the 6pin female end of the PSU's 6+2pin cable and just ignore the +2 part and hope it all comes out ok on the other 6+2pin end which plugs into the gpu. So 6+2pin psu cable ---> 6pin NZXT extension ---> converted to 6+2pin NZXT plugged into gpu.
