- 26 Dec 2009
hi,
i dont know if im being stupid with this or not but i think my CPU has underclocked it self to a 840Mhz CPU.
It struggles to run webpages in that i have a very jerky scrolling and also youtube videos take a couple of seconds to catch up with them selves.
Even writing this out to you now its struggling to put the words on the page faster then i can type them.
When i load up CPUz on the first screen it says CPU's and at the bottom it has a run down of the current speed etc the format is like this:
Core speed: 840Mhz
Multiplier: 4x
bus speed: 210Mhz
HT link: 2100Mhz
on Windows it self it says its a 3Ghz Processor but only scores 2.9 on the index and on the little window in the top right hand corner that you can have running it also says 3Ghz but i thought CPUz was a live feed of what the processor is currently running at, which is what iv put above. Even when im loading things up this number doesnt go above 840Mhz. Unless of course your meant to add the HT link and core speed together to give you near the 3Ghz?
Any clarification on the matter would be great.
Mobo : Asus M4A77TD Pro
Processor: AMD Phenom 2 x2 545 3Ghz
Graphics Card: Gigabyte HD5750 1GB GDDR5
RAM: DDR3 4GB (3.25 usable) (cant remember the brand)
Screen: Samsung 22"
cheers Craig
Core speed: 840Mhz
Multiplier: 4x
bus speed: 210Mhz
HT link: 2100Mhz
Screen: Samsung 22"
cheers Craig
Assuming the unlocked cores are not defective and stable at stock, that's a win and a half
