We are considering moving at the moment and broadband speed is very important to me. Whilst I am aware that I can get the current phone number of the property and put it into one of the various databases, I am also aware that this is not 100% accurate and what I'm trying to avoid is buying a house and then finding out that the internet connection is awful (and i do realise that this will be a sujective term for everyone concerned!). ADSL products are the only option here by the way, as only about 50% of the village that the property is in has cable available.
The only other real solution that I can come up with is to ask the vendor (who doesn't have a broadband enabled line at the moment) if I could plug a filter and my modem into the master socket and then to login in to my router wirelessly with either my phone or laptop to see if i can get an attenuation reading which should give a fairly accurate reading of line quality.
However, what I am not sure of is whether a modem will be able to get this stat if there is no broadband connection enabled on the line?
Does anyone know if this will work, or can recommend a better way to make sure that I don't spend the next 10 years or so living in the broadband slow lane?
Many thanks
Spudgun
Many thanks
Spudgun
