Is it possible to do this...
8 Jan 2009
North East
If you enable speedstep, EIST, C1E whatever the options are, the fsb and multiplier is reduced, so on my q9550 it would be x6 multiplier instead of 8.5x
anyway, im running a high idle vcore at 1.425v (which i was told is ok, its the load core i need to watch - 1.3625v in the safe intel range).
is it possible to bring the idle vcore down with the multiplier and fsb, and it only shoot up under load, so that way i would never idle at 1.425v???
i dont trust the idle vcore im using :o
ah, i think i found it.
in my bios i set:
C1E > Disabled
C2/C2E > Enabled
EIST > Disabled
one of them has now put my idle vcore at 1.376v instead of 1.425v :)
does this look good:
High voltage is always stressing insulations in CPU regardless is it idling or doing something.
