Is it possible to force anti-aliasing to work in older PC games?
24 May 2003
UK
I often wonder why despite having a Radeon X800 graphics card with anti-aliasing functions, on some 3D games like for example racing games, even if I have them enabled in my graphics card properties they still don't work in the game itself :confused:
It is as if the game engine is ignoring the settings.
Is there any way to force the game to accept the settings or is this simply not possible?
I realise that setting the anti-aliasing to 6 would slow the game down to a crawl (I think) so if it did work I was only going to set it to 2 just to get rid of the worst of the jaggies.
Any ideas anyone please?
LabR@t said:
? should work m8
It doesn't though :confused:
One of the games I am referring to is F1 Challenge 99-02
Here is what I have found from one of the Help files:
"Users with FSAA enabled on video cards that support this feature may notice occasional minor graphical issues - we recommend that FSAA is disabled when playing F1 Challenge 99-02. FSAA is enabled and disabled using the video card application provided by the video card manufacturer."
It couldn't be working as I can still see 'jaggies' when running the game or perhaps because I only have the anti-aliasing set to 2, this isn't enough to get rid of the 'jaggies'?
Umm... you're complaining about FSAA not workign on a game that the developers reccommend not to have it enabled on? :confused:
Richdog said:
Umm... you're complaining about FSAA not working on a game that the developers recommend not to have it enabled on? :confused:
Well yes but that was just an example.
I have other games that would benefit from FSAA but I can't get it to work in any case.
Not to worry :)
Occasionally there are games where it just doesn't work even when using the driver control panel to override it (e.g. NOLF2).
Incidentally with FSAA at 2x it's highly likely you will notice jaggies anyway, unless using a very high resolution like 2048x1536 or something.
I have also noticed this but thankfully most games do seem to work by trying out what I say below.
Thanks.
The problem is solved and I can now run most of the 'problem' games in a slightly higher resolution (1152 x 864) and since upgrading to the latest CATALYST™ drivers I now seem to be able to 'force' FSAA to work (in most of them anyway).
I am only now getting back into PC gaming after an absence of over a year and as a result my old CATALYST™ drivers were dated 29/10/2004 (26.2 mb) and were probably out of date :eek:
The drivers I am now using are dated 16/1/2006 and are only 11.6 mb in length!
This is strange that the newest drivers are less than half the length of older drivers meaning that size obviously isn't everything :rolleyes:
Thanks to everyone for their help in this thread.
