basically ive got 2 vga only monitors, however i wasnt able to connect the 2nd screen due to wrong dvi input on my gpu to the dvi-i to vga adapter, so untill i change gpu, i figured id get my 24" 1366x768 tv out the garage, it only has a single hdmi input and nothing else and then connect that along side one of my vga screens, however im guessing they both cant run together off the gpu?
they are both detected in multi screen option of the nvidia control panel and both set to 1366x768(pc mode for tv) or i use the tv 1080i option to match the vga screen native 1440x900, my vga works as expected, but not the tv... normally in these cases id use onboard graphics for vga outputs to get both working, but obviously the 860k has no gpu part.
so is it possible given the 710 should be able to dual monitor or would it only work using both hdmi + dvi input given they the same thing basically?
