I have a pretty crappy PC as its 6 years old and I will be buying a new one soon.
Is it possible to overclock this cpu?
CPU Properties
CPU Type Intel Celeron, 1000 MHz (10 x 100)
CPU Alias Coppermine-128
CPU Stepping cD0
Instruction Set x86, MMX, SSE
Original Clock 1000 MHz
L1 Code Cache 16 KB
L1 Data Cache 16 KB
L2 Cache 128 KB (On-Die, ATC, Full-Speed)
CPU Physical Info
Package Type 370 Pin FC-PGA
Package Size 4.95 cm x 4.95 cm
Transistors 28.1 million
Process Technology 6M, 0.18 um, CMOS
Die Size 95 mm2
Core Voltage 1.75 V
I/O Voltage 3.3 V
Typical Power 9 - 22 W (depending on clock speed)
Maximum Power 14.0 - 33.0 W (depending on clock speed)
CPU Manufacturer
Company Name Intel Corporation
Product Information http://www.intel.com/products/processor
Cheers
CPU Properties
CPU Stepping cD0
L1 Code Cache 16 KB
L1 Data Cache 16 KB
CPU Physical Info
Die Size 95 mm2
Core Voltage 1.75 V
I/O Voltage 3.3 V
CPU Manufacturer
Cheers
