Is it possible to remove coolant stains from acrylic/perplex?
27 Apr 2012
London
Is it possible to remove coolant stains from acrylic?
I have a reservoir that have some stains on the acrylic, is it possible to remove the stains without damaging the acrylic?
I tried with water and neutral soap but it didn't work.
Oky dip the tube res in hot soapy water and use a baby bottle cleaning brush (50p from most supermarkets) and give it a bit of a clean this should remove it.
Thanks,
It removed 95% or more.
Without water on the reservoir you still can see it, but as soon as you put water inside you cannot see anymore.
Excelent. Thats good to know :) id send you blitz part 2 but giving it a rub with hot water and fairy Liquid will do a better job on some thing like that.
