Is it possible to use a lower resolution on a 1920x1080?
16 Dec 2008
Lincolnshire
Just wondering if it possible to use 1680x1050 on a 1920x1080 display, I know I can set the resolution, but is it possible to actually set it to 1680x1050 and actually use that amount of pixels?
If so how do you do it?
Thanks, it works, but had to apply scaling using the GPU setting and not the monitor setting in Nvidia control panel
