Hi, was just wondering if it would be possible to re-use parts from my current machine (Compaq SR5139) to put into another machine which would be newly built with parts from OCUK ofc. I am going to be getting around £300 soon and i am contemplating spending it on a new machine but as it is a very limiting budget, i plan to re-use parts from my current, fairly acceptable machine.
The current PC is a Compaq SR5139 consisting of:
Core 2 Duo E6550 2.33GHz
2GB RAM
320GB HD space
256MB nVida Ge-force 8400GS card
They seem to restrict releasing info on the other parts and i cant find a website that shows every bit of hardware in the PC.
I'm not sure on which bits would be best to keep and which bits would be best for replacing.
Could i build a better machine than i already have with this idea?
Thanks.
2GB RAM
320GB HD space
Thanks.
