- 25 Mar 2011
Hi
Is it possible to install Windows 7 on a SSD in IDE mode?
Regards
Regards
It will do. Most boards with sata ports do.
I have been in contact with OCZ support and showed them my posts from **** and another forum (asking about installing Windows in IDE mode) but they still won't accept that the drive may be faulty.
What did they believe the issue was?
If your motherboard has Raid mode, try using that as it should include AHCI support.
I've always gone by the following (taken off another forum as they put it very nicely):
- IDE mode, in which neither AHCI nor RAID is enabled.
- AHCI mode, also called SATA mode, has AHCI enabled but not RAID
- RAID mode, which is the same as AHCI mode but with RAID support
Not necessarily. I've had a few that have lost AHCI during bios upgrades or have never had it supported from the outset
best google 'M4A78LT-M LE ahci'
