Is it possible?
18 Jun 2010
Essex
I want a small form factor PC that I can take to and from university with little hassle. Currently I have a laptop but gaming on a laptop sucks.
If I'm honest I only really play CS:S.
I was looking at ITX but from what I've seen you only get 2 PCI slots (if that) and I'd have to have a slim graphics card (rubbish) and a decent sound card. So it looks like mATX is the way forward.
I want to spend as little as possible, it just needs to be able to play CS:S at 1080p and maybe CS:GO at 1080p but not necessarily at the best settings when that comes out.
£600 budget, but I will push it if needs be. OS is not an issue. Also I have a Optical drive. I like the idea of the cube cases, but they seem quite expensive. I'm happy to go second hand.
Cheers.
lol I was about to spec similar
YOUR BASKET
1 x EVGA GeForce GTX 460 Superclocked FTW 1024MB GDDR5 PCI-Express Graphics Card (01G-P3-1363-KR) £124.99
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £95.99
1 x Samsung 128GB SSD 830 Notebook/Apple Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC128N/EU) £85.99
1 x Asus P8H77-I Intel H77 (Socket 1155) DDR3 MiniITX Motherboard £83.99
1 x Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS) £66.98
1 x BitFenix Prodigy Mini-ITX Cube Case - Arctic White £64.99
1 x Cooler Master Silent Pro Modular 500W '80 Plus Bronze' Power Supply £43.98
1 x Adata XPG Gaming v1.0 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (AX3U1600GC4G9-2G) £38.99
Total : £605.90 (includes shipping : FREE).
The i3 cant be overclocked so yes you could use the H77 as it still has lucidMVP to use the IGP to boost the GPU. The Z77 mobo i used earlier had integrated wifi to help justify the price.....mini itx isnt cheap :(
I used the 460 here too (I own one), it's a good card and allows HDAO lighting and has CUDA support......is it really worth £40 more than the 6850 well I'll let the OP decide, probably not in truth. I don't want to get carried away doing specs as the offers will change (that PSU might well go pack up in price).
well spec is exactly the same bar the case and im assuming op has all summer to decide since uni starts in october anyhow
LOL that's why they are similar
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x MSI HD 6850 OC 1024MB GDDR5 PCI-Express Graphics Card £83.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £82.99
1 x Xigmatek Asgard Pro Gaming Case - Black £31.98
Total : £614.89 (includes shipping : FREE).
Not many budget cases in stock to be fair. This case is cheap and just a lil smaller than say the zalman Z9. He did say he wanted mATX, these cases can take ATX so that's what i've used.
i5 3570K uses less power than sandybridge and has a better IGP. On a Z77 mobo it can be overclocked, you still have lucidMVP to boost the 6850. Plus the rest of the goodies from the previous specs SSD, modular PSU etc ;)
Matx will be needed because I want a sound card as well as a graphics card. On ITX you will need a single slot gpu which aren't very good. dont worry about the sound card in the budget that's separate.
