The extra wattage alone won't damage your laptop
The wattage is simply a combination of the voltage and amperage of your PSU
More volts can kill your laptop, more amps won't make any difference at all
Say your standard 60W PSU has a voltage of 24V. This would mean a current of 2.5A (watts = volts*amps)
If your 85W PSU also has a voltage of 24V, this equates to a current of 3.33A. As the volts is the same but the current is higher it doesn't matter at all - it will work fine
If, however, your 85W PSU has a current of 2.5A but a voltage of 32V then don't use it as this could damage your laptop (the voltage is higher)
The other issue to check is the polarity of the connector which will be shown on the PSU itself
Basically, check each PSU. If the volts and polarity are the same then it will be safe to use
