Is it safe to use Ccleaner reg fixer?
18 Aug 2004
Leeds, UK
Well I tried Ccleaner tonight and scanned my systems registry with it and it found loads of unused DLL's and missing links, I decided to fix all and it made a backup of my old registry I am just thinking if it has messed anything up will it be OK to just run the old reg file and it will restore all?
I used it once to clean my registry, it went pear shaped. Probably just me being unlucky, I'd use it again though. :)
Been using CCleaner for a few months now, including the reg cleaner. Haven't had a problem yet so I'd say it's safe to use :)
Thanks for the response, I did clean the reg and it seems fine at the moment, I have the backup reg file just in case, seems a good bit of software, much faster then using disk cleanup :D
