Is it true?!?!?!?!?!?
it is overclocable , but you can clock on the volts it is running you cant increase volts , also they clearing stock for 6950 and 6970.
It is clockable, and I did clock mine but put it back to stock after a while as I noticed no difference. Like you say, it is fast enough as it is. :)
I will let someone else answer that one. Been on the ATI bandwagon for a while now, ever since my 7660GT anyway.
You can never be sure to be honest and could spend ages worrying about it when in the real world, any differences are minimal.
Just be rest assured, my 5870 does everything I want it to and more. I game with a 24' monitor and on BFBC2, it eats it up. I use V-Sync as I don't like screen tear and it just sits on 60FPS with the settings maxed at all times. :)
930 on the gpu is better than nothing :). I've heard horror stories that these won't clock at all and the pcb is made really cheaply. 2 free dx11 games aswell to throw at the card too perfect bundle :D
