I need to buy a new bike for the 10k commute to work but I'm torn between buying something cheap from halfords, something second hand off pinkbike, or something relatively nice from my local bike shop. The latter includes a bike fitting on a adjustable jig to work out which dimensions work best for people which sounds attractive as I seem to have odd proportions and my old bike (got nicked in December
) never fitted very well.
Has anyone had one of these and can you comment on its effectiveness? I like the bike shop but they have a noticeable premium so if it's not worth it and I'll be able to get much more bike for the money elsewhere then that's something to think about. But then again, if it makes the same difference as getting running or climbing shoes fitted properly, it's definitely worth it since I'll be cycling most days!
My budget is up to £1000 for a hardtail that'll do trail riding (as I've no mountain bike anymore either), or £500 if it's something more dedicated to road/bridleways. Anyone care to throw some opinions at me?
