Hi Stinka,stinka said:ive been wondering about this as my evga 680i gets hot and the nb fan is so noisey
how do you get the old heat sink off witout damaging anyting?
cheers
stinka
Hey Dante,dante6491 said:Yup, my HR-05 is a tad unstable, however when it is on, it does cool pretty damm well, especially when you strap a fan to it. (a 60mm Akasa Amber for me). Im just wondering if the Noctuna mounting mechanism works with it.
Do that or get a better cooler. A fan plus postage is about half what the Noctua delivered works out to be. I know what i'd choose!Mattus said:Are we sure that these temps aren't gonna damage our DS3 northbridges? Mine is running at 450FSB and the NB is literally too hot to touch under load, I'd put it at 70-80degC. Might stick a fan on it - it's worrying me.
Love it when companies start blaming one another like that! Soooo professional!dante6491 said:Hiper are saying it is a problem with the motherboard, DFi are saying it is a problem with the power supply. Still awaiting emails from both.
cheers
stinka
Did something like that on my old SLi DR and it worked wonders. Temps on the CPU's power section plummeted from 70 degrees down to 45!Mattus said:My computer is pretty quiet and I hate whiney 40mm fans. I might rig up a low-speed 80mm and have it cooling the RAM and mobo components as well as the NB. Good plan?
