No no no no no no. A used vive pro dependant on the price is potentially a good deal because it give you the light houses.
But otherwise just no if talking about new.
and if ur going used, the reason ur going vive pro is for OLEd AND wireless.
the £899 OC are charging can get you near enough give or take a few quid:
1. A full Valve Index package with HMD, base stations 2.0s and next gen controllers
2. A pimax Artisan HMD + 2.0 light houses + next gen index controllers
3. A Rift S (399) AND a Quest (399) + KSC75 headphones for the Rift S + Mamut grips for both devices
I'd take any of those 3 over a used Vive Pro.
Your options should be:
1. Oculus Quest (same Vive pro panel but clocked at 72hz and uses Oculus Link software to encode vidoe data which introduces a hit to clarity and can cause some artifacts)
2. Rift S (bargain basement headset IMO with low refresh rate, the worst of the VR headsets LCD panels but a GREAT price and great clarity per £, however lacks audio, physical ipd and uses the same controllers as the quest despite them now being a generation old, no improvement in fov etc..)
3. Index (main con being its an LCD panel rather than OLED I doubt we'll see a return to OLED for a while; main issue being the valve customer support and QA is simply not good enough)
4. Pimax Artisan (probably the best value headset on the market, combining a next gen field of view with most of the features of the Index, its main cons being its from a chinese company which are still very new and have crap customer service relatively, will require more tinkering than the other 2 headsets and no good enough audio solution (basically like the rift s)
5. Pimax 8KX (very expensive, £1000 for the HMD but it has image quality that has been described by MRTV as the BEST in consumer class, that means its overall better than XTAL and Acer Varijo headsts which are much much more expensive so for your money you're getting an AMAZING deal.. in native dual 4k mode ur capped at 75hz and you don't have a good audio solution for it other than headphones, BUT it can downscale down to 8K+ and deliver 120fps I believe and definitely 90hz)
I'd say the best option is the Index as you have a clear upgrade path to the 8KX or Artisan if you fancy a wider field of view. The base station technology seems here to stay and I can't think how Oculus will better the Index controllers in 1-3 years so they're all good investments as far as technology goes.
the Index headset is the only headset which IMO combines audio and visual fidelity as a complete high end premium package which is sad.
If you are a tinkerer, I'd go for the Artisan.
If you love the high end best of the best products, then the 8KX.
If you have a budget, I'd go for the Quest as portable VR is fun and the OLED panels via Oculus Link make some games REALLY nice.
If you have a budget and find the Quest uncomfortable, then your choices are a used Vive or a Rift S. I'd opt for a used Vive if your IPD is not in range as again you have a clear upgrade path, but otherwise the Rift S is a really nice entry level point into VR.
The issue with VR is it can get expensive once you buy the headset. aka buying headphones, wrist supports for controllers, presception lens adaptors, cases, charging cables... you can end up paying an extra 100-200 or even in some people's cases 300 pounds... I feel its important people don't spend more than their headset is worth. buying £100 audio solution for a Rift S for example is silly IMO.
