is it worth installing gpu to a68n-5100 apu?
9 Jan 2016
Derbyshire
picked a system up at the weekend, got the a4 5100 apu, i didnt research, so didnt realise it was an onboard setup, anyways is it worth adding a gpu to? i dont know what this thing be capable of ha
I suspect very little. If you have a GPU sitting around then by all means experiment, but I wouldn't spend money on upgrading it.
thanks for that, yeah i suspect it would be a little similar to an AM1 quad sempron i used to have which wasnt too bad, i suppose the good thing with this apu is it should fit in a really slim case if i dont use a gpu given the design of it. does need memory upgrade though.
