Is it worth it?
3 Jul 2013
Is spending 792 euro with shipping (Bout 687 pounds) for this pc?
Comes with OS, Monitor and keyboard.
Case
STYLISH PIANO BLACK ENIGMA CASE + 2 FRONT USB
Processor (CPU)
Intel® Core™i3 Dual Core Processor i3-3240 (3.40GHz) 3MB Cache
Motherboard
ASUS® P8H61-MX USB3/SI: uATX, USB 3.0, SATA 3.0Gb/s
Memory (RAM)
4GB KINGSTON DUAL-DDR3 1600MHz (1 x 4GB)
Graphics Card
2GB NVIDIA GEFORCE GTX 660 - 2 x DVI, HDMI, - 3D Vision Ready
Free Item
FREE SPLINTER CELL BLACKLIST GAME with GTX 660 & 7 Series GPUs!
Memory - 1st Hard Disk
500GB 3.5" SATA-III 6GB/s HDD 7200RPM 16MB CACHE
1st DVD/BLU-RAY Drive
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Memory Card Reader
INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Processor Cooling
INTEL STANDARD CPU COOLER
Sound Card
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities
10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options
MIN. 2 x USB 3.0 & 4 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Power Cable
1 x 2 Metre UK Power Cable (Kettle Lead)
Sorry if some info is useless, its a lot of money for a fourteen year old to spend haha
I would consider this:
  • 7870 instead of 660
  • Good branded PSU (XFX, Seasonic, Corsair) as un-branded can be dangerous
  • 8GB would be better and for the price I would expect that
  • At least a 1TB drive/128gb SSD
  • Remove the BluRay player
You'd be better getting us to spec according to your budget in all honesty.
Case
Processor (CPU)
Motherboard
Memory (RAM)
Graphics Card
Free Item
Memory Card Reader
Power Supply
Processor Cooling
Sound Card
Network Facilities
USB Options
Power Cable
you should remove the prices as is not from here, its from other website called **********t, i am right?
also for that price go for a i5
Things I would be considering:
Unknown PSU - Is it a beQuiet or just 'Quiet' ?
Has a H based P67 motherboard
Has a standard retail CPU cooler
Has a 500GB HDD. Would want a new gen 1TB platter based HDD.
USB/Sound/NIC are all on-board....should not be listed separately really as it's a feature of the motherboard, not the build.
Are you getting this from a different website? If so why dont you try to make it yourself,you would save a lot of money and enjoy the experience, i know your 14 but youtube has so many videos.
