30 Jul 2008 at 14:19 #1 Stinky Stinky Soldato Joined 28 Mar 2005 Posts 9,250 As title really. am i going to notice bid differences?? are the bugs that bad? is it easy to do? im currently using my orange sim and will want to carry on with that obviously. so is it easy enough to do?
30 Jul 2008 at 17:27 #2 Will_3rd Will_3rd Soldato Joined 13 Dec 2005 Posts 6,418 Location Reading, Berkshire Not experienced any bugs lately, only ran into sluggish texting and contacts list so far. Easy enough if you follow the instructions Pwnage tool gives you, should work fine with the Orange SIM.
30 Jul 2008 at 20:51 #3 Stinky Stinky Soldato OP Joined 28 Mar 2005 Posts 9,250 sluggish texting eugh i couldnt cope with that as bad as that sounds
30 Jul 2008 at 21:28 #4 Will_3rd Will_3rd Soldato Joined 13 Dec 2005 Posts 6,418 Location Reading, Berkshire your probably right, might be worth waiting to see if a fix arises in 2.0.1
