is it worth me starting morrowind now
22 Oct 2004
Ive had this game for about 3 months now and havent really got into it, but when i did play it i quite enjoyed it. But most of my time now is taken up by work so by the time i get home i just wanna play css, bf2 or guildwars. Is there any point as oblivion will be out soon and and my time will be totally gone with that.
The game is massive so I would recommend waiting for Oblivion.
Unless you play the game every day until Oblivion comes out then you may finish it but that depends on whether you complete the side quests ect.
I personally have finished it twice and was going to play it again in the new year after I found out the delay on Oblivion.
I think I'll wait until March.
i noticed that the xbox360 version of oblivion is due out at the same time as the pc version.Is there likely to be any difference between the two versions do you think. Which version would be best? I haven't got an xb360 currently but this title might convince me to get one if it's likely to be any better;)
the developers have said the obvious really. If you want absolutely no sacrifice of anything for the visuals, then a top end PC is the only way to go. An xbox 360 will rival a usual good pc though, and be better than low spec pcs.
PC is the way to go, as 360 does not get the construction set. There are some brilliant mods available for morrowind and hopefully the community will continue their work for oblivion.
I wanted to love Morrowind and I played it a lot and bought it twice!
The only thing that got to me what the NPC's werent very convinicing i.e "interactive database".
It looks like Oblivion is going to be a lot better in this respect, so I for one would wait. :)
I thought now would be a good time to answer this question, but yes I think you should still give Morrowind a go. I believe they patched out any bugs that were visible at launch too, so your gaming experience should be smooth sailing.
Let us know how you get on!
I thought now would be a good time to answer this question, but yes I think you should still give Morrowind a go. I believe they patched out any bugs that were visible at launch too, so you're gaming experience should be smooth sailing.
He should wait a bit longer for better hardware to come out to make sure for a smooth experience. Another 20 years ought to do it :D
