is it worth me upgrading?
7 Jul 2010
Lancashire,UK
I have a ATI 4800 radeon is it worth upgrading to a Sapphire ATI Radeon HD 5850 Extreme 1024MB GDDR5 PCI-Express Graphics Card?
That 5850 and the 5830 on OCUK atm is the cheapest performance/price on OCUK atm.
Yes and No, it depends on what your other componants are.
Monitor Resolution?
System Spec?
There's your answer. No point just for tessellation really. Unless power draw and reduced noise / temps are an issue I'd stay with what you have until either it gives out, or you start using a higher resolution / need more horse power etc.
or buy a better monitor ! For less that price of a 5850 get a widescreen 19" or 20" that a 4850/4870 would be fine at.
