Is it worth using lower end Sound cards on High end motherboards
14 Jan 2010
Essex
Is there any point or advantage in doing so?
I have an Asus Crosshair VI Hero and an Asus Xonar DG SI 7.1 Sound Card
Just not sure whether its worth using or should just sell?
It seems like the onboard solution is better than the Xonar DG on paper but since you have both, time permitting, you should test them both and decide which sounds better with the speakers/headphones you have it connected to. If you are using headphones, the Xonar has a 150ohm headphone amplifier which l am not sure that the onboard solution possesses.
Probably only worth using the DG over the onboard audio, if you want to make use of Dolby headphone. That's one thing even a lot of more expensive boards don't have; surround sound effects for headphones. If you're not bothered about that, just stick with the onboard audio.
Generally not worth needing a additional soundcard on the higher end boards these days for most people and day to day usage.
I have to admit to always assuming that a dedicated card will always be better than onboard, but this is simply not true across the range of devices.
If you have a half decent speaker setup, then you really need to set aside a good chunk of time and play a good range of tracks on both devices and see how you feel.
You dont need to do too much messing about... You can hve the card plugged in and the onboard enabled in the BIOS and simply use the Control panel to select which devidce you are wanting to play your sound from, the only issue is the speakers and/or headphones will be needing to be plugged in and out etc.
Im in a constant state of what devices to use myself. My main speaker setup right now, is a combination of multiple bits that I have tried to get the absolute best possible sound I can, and Im also using multiple Speakers too, so I have the best possible Bass, MidRange and Treble, but they are still analog and while they are analog, I do have a few Digital options, but they just dont do it for me.
My card at the moment in my main PC is an Asus, but the last time I had a head to head, I was running it against the Creative ZXR. Around the same time, I was also trying my damnedest to justify buying the Logitech Z906 speakers but they are still in teh box almost a year after buying them, even though with multiple inputs, they would be a great choice for me instead of me having only one PC connected to these now.
Oh god, why the heck do I waffle like an idiot?
Just try them out and only you can judge the best... Everyone has different hearing and everyones music tastes are different, so what I may find perfect, you may find awful.
