Is malware in temp folder harmful?
12 Jun 2004
Exeter
I just got my parents computer working after it being down for about 18 months.
I installed Kaspersky AV 2013 and did a scan, which detected the following:
Trojan-Spy.Win32.EmailGrabber.ak Deleted 12/03/2013 19:08:11 c:\documents and settings\*****\local settings\temp\
I think the actual file name of it was 49.tmp
My question is, would that Trojan have been active/harmful or is it just a temporary file? Where would it have come from?
If memory serves most malware and viruses dump themselves and run from the temp folder, so it would have been harmful even in that location.
I'd run a few more scan tools to be sure
MBAM is a good one
hijackthis will tell you if that file is being called at startup
Thanks.
Kaspersky seems to have dealt with it and I have run MBAM and SAS to be sure.
I couldn't see anything suspicious in start up but the PC did display a rundll error every time windows booted; it was trying to launch a .dll file at start up but the file was not there. I'm wondering if an anti virus in the past had partially deleted/removed the trojan.
