Is Memtest86+ the be all and end all with regards to memory/system stability?
16 Nov 2005
West Midlands, UK.
I ask as I'm Prime(12+ hours), OCCT, SnM, Aquamark, SuperPi and 3Dmark05 stable, I have tried 2 different sets of memory in two different motherboards, but every type of configuration I've tried throws up errors in memtest86+.
So should I be concerned about the memory errors in Memtest and try to find a solution that would be costly to do(the only other avenues left to explore are PSU or CPU related); or just ignore the errors and put it down to one of lifes mysteries?
dagwoood.
Dutch Guy, it's normally test #4 that it fails on.
I came across a guide last night that says test #4 failures are normally related to HTT or Vcore issues. So I started Memtest after upping the Vcore, but it failed after a couple of cycles on test #6.
Everything goes through your memory so having 100% rock solid/stable memory is paramount imho...
If every other stability test program is giving your memory a full bill of health when run on their most extreme setting then I would suggest it's probably a compatibility issue with Memtest?!?! Have you tried a different build of memtest? Try a few different builds of Memtest and Memtest+.
Also all these other stress programs you have tried (I think) run within windows where-as Memtest run's in DOS?!?! Could you have an issue/problem in DOS????
Also do you not have any other memory lying around that you can chuck into the rig and test??
Thanks for the suggestion guys :)
I disabled USB in my BIOS and ran Memtest86+ v1.65, but it showed errors in test #4 on the first pass.
I then tried Memtest86 3.1a, but that showed errors also.
I then downloaded MemTest 3.4 which runs in windows. It prompted me to run two instances of the program in view of the amount of memory I have on my system(2GB)and I ran it though 10 cycles(which took 6 hours, that's why it's took so long to get back to this thread)and they didn't find any errors.
I think id10T_error may have been onto something when he/she suggested there's a compatibility problem with running the memory tests in DOS.
If I can concurrently run s/w to test memory for 6 hours and not get any errors, taking into account the hammering a CPU/memory controller would take to do this, I'm not going to loose any sleep, or pour money into, trying to cure a problem that Memtest86+ says I have. Not when all the other tests I've run haven't indicated any problems either.
Thanks everyone for the advice, dagwoood.
I agree, leave it as it is and only go troubleshooting if you get BSOD's, CTD's or lockups.
