Is my 360 dead?
5 Nov 2002
Belgium
I just powered it off 10 mins ago, I want to turn it back on now and it won't boot. The button to press it on flashes red
Rip lemm's 360? :(
It actually has a special code to display for overheating? :D They must have realised it was a high probability then I guess? That surprises me. It sounds like they need a better cooling design if non-faulty machines are overheating.
I know it's hot here for the UK but it's nothing compared to the States at the moment where they're having 40-50C temps. The 360 should be designed to cope with those, never mind our ~30C temps.
my 360 flashed all 4 quadrants about a week ago, it was after I had taken the hard drive out to clean around it. So I turned it off, checked the hard drive was seated as it should and restarted it; and it was fine.
A rolleyes is too good for that post.
The original Xbox displayed a certain sequence of lights too, maybe MS just like to cover all the bases and try and make diagnosing any problems as easy as possible?
Depending on the household, it could be warmer this christmas in a living room/bedroom when somebody has the full heating on OTT. It's better to actually know that the console is overheating rather than think it's just deaded, as you could probably overheat a sky box or amplifier quite easily by poor ventilation, and all they'll do is throw a wobbly and hate you for a bit. :p
Nah, they have red lights for most problems. It's just a way of indicating that there is actually a problem. If was most likely 3 red lights, which means a internal error. If it was 2 red lights, then it meant that your AV cables weren't plugged in properly. :p
Overheating is classed as an internal error so that explains the three red lights.
Not sure about 1/4 red lights though.
1 Red light (any quadrant) is hardware failure
2 Red lights is overheating (should work after a while)
3 Red lights is hardware failure
4 Red lights is no AV output found (ie its not connected to a tv)
This is a rough guide.
young lad said:
Sorry was me i did a search for summert and this was just one i responded to lol wern'tmany on list.
OT, but this is the 3rd post I have read of yours today & you actually type how you would speak.(Providing you have lived in Mansfield for some time) it's quite sloven but cool :p .
Back to topic kind of :), with the launch consoles & the problems that people had, red rings etc, did MS actually acknowledge a fault & change any manufacturing procedures or are the faults still as common in recently manufactured consoles?
