Is my 360 knackered
Tea Drinker
Don
13 Apr 2010
Sunny Sussex
Hi,
Playing away tonight when the game action sounds and the menu plonks have disappeared, I can't hear footsteps but can hear the game background sounds.
Any ideas?
Also my NAT has gone to moderate if that makes any difference as it's usually open.
Thanks
Hi,
Any ideas?
Thanks
Can you be more precise, cable become loose out of xbox?
I was referring to NAT. He has mentioned NAT so doubt it's SP. I didn't mean sound is router related. Just his connection
I don't know why he mentioned how strict his NAT is if he has a sound problem though? :confused:
He needs to try several games/install to HDD to determine it's not a dodgy disk or something, and if it's a problem in other games too then he needs to try a different cable imo.
