Hello everyone, not sure if this is the right place to post this. Been ages since I've posted here. I have a feeling there's something wrong with my new CPU. Here are my system specs:
Here is everything I have tried:
Everything else is working correctly with one RAM module installed. No other issues.
Edit: My problem ended up being the CPU for anyone that finds this post in the future. I got it exchanged and everything is running fine now.
- CPU: AMD 3700x
- Motherboard: ASUS ROG Crosshair VIII Impact, X570
- RAM: Corsair Dominator Platinum RGB 32GB (2x16GB) DDR4 3200MHz C16 (CMT32GX4M2C3200C16)
- PSU: Corsair SF750 80 Plus Platinum
- GPU: EVGA GTX1070 FTW
- System boots with RAM only in slot A1.
- System does not boot with RAM only in slot B1 or with RAM in both slots.
- The RAM in question is on the QVL.
- I have made sure all PSU cables are secured correctly at both ends.
- I have checked the CPU for bent pins; there aren't any I can see.
- I have reseated the CPU and rebuilt the system a few times.
- I have loosened the CPU cooler screws a little (I've heard this can help)
- I have updated the BIOS to the latest version, didn't work with original BIOS or new one.
- I have adjusted the RAM speed in the BIOS to match the speed rated on the modules.
- Tried with DOCP enabled and disabled
- I have replaced the motherboard, same issue.
- I have replaced the RAM, same issue.
- I have played around with some BIOS settings, including RAM voltage. Nothing seems to work. I have cleared CMOS and power cycled and few times, and nothing.
- I do not have another CPU to try.
