Is my 4070 pci-e lane damaged?
17 Feb 2024
BRAZIL
3 Feb 2017
Mondas
It
Hello
I´ve bought this GPU for just 2 days ( gigabyte 4070 aero) and in the second day i took the gpu from the mobo to do some cable management and i´ve noticed this
https://imgur.com/a/HGBS03H#bNGeGTd
https://imgur.com/a/JB9McOY#EFcbUWv
https://imgur.com/a/mJGIPiC#ZPHhI0p
i´m almost sure i did not touch , damage or applied excessive force to the gpu
these 3 pins are bent simetrically in both sides
Is it a problem or should i rma?
The gpu is working properly
Thanks
Its fine. Don’t worry about it.
