- 19 Dec 2017
I've been looking through the Timespy results thread this evening and see my ~10800 CPU Score is way lower than anyone else with a 5800x
I was using Auto OC to achieve that score, so I decided to look at potential factors.
I'd been running my memory at XMP (2x16GB Micron-B @ 3600Mhz 18-22-22-22-42) so I decided to try DRAM Calculator timings but couldn't get the machine to post at 3200Mhz with those settings. Loosening the timings let it boot, but it was unstable - it seems there's no room to improve ram timings.
When that didn't work, I had a play with PBO - I set all cores at -15 except the two strongest at -10 with a max boost of +50Mhz which seemed to be about the strongest I could achieve without starting to test individual cores.
This got me up to 11460 which puts me joint with the lowest 5800x score in that thread - most are 12-13k+
So the question is, is the swing of the silicon lottery this large? Do I have a problem? Could I push OC harder or is it my Memory?
