Just got a 4k monitor so I thought id try to plug it into my old build (I mainly just use my macbook as I dont game often) and turns out the 560ti doesnt support 4k...
Im using a Corsair Hydro H60 High Performance Liquid CPU Cooler to cool my i5 2500k, everything good you think to OC that?
anyway the rest of the build is:
-OcUK GeForce GTX 560Ti 1024MB GDDR5 PCI-Express Graphics Card
-Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
-OCZ ZS Series 550W '80 Plus Bronze' Power Supply
-Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
I've got a HDD in there and added an SSD about a year ago too.
What would you recommend to upgrade, i'm assuming GPU is the main one, what would work so I don't bottleneck, i'm not upgrading till 2-4 months time btw
