Hi,
I've just installed my new Sapphire 6950 TOXIC and I'm not sure if it's all running quite as it should be. I've not got any functional problems, i.e. it all powers up fine, no corruption or crashing but I'm not sure if the performance is correct.
I've run the Heaven benchmark as on the big thread in here and got these results.
Firstly I don't know if that a decent score for my system (see sig for spec) but I think it's at least ok.
My main uncertanty is that I don't seem to be able to change that score at all. I got that score with my cpu at stock and with the 6950 out of the box, since then I have over clocked the cpu to 3.3GHz, switched to the 6970 BIOS on the 6950 (GPU-Z reports that the extra shaders have unlocked ok) and upped the PowerTune limits in the CCC to +50% but I still get the same score (+/- 10) each time I rerun the benchmark?
In the CCC I have everything set to Application Control and I have tried running with my 2nd monitor disabled as well with no effect.
Is there something else that could be bottlenecking me or am I worrying over nothing?
Many Thanks,
Ross
Many Thanks,
Ross
