So I recently purchased the Vapour-X 7950 OC version at 950Mhz which for some reason didn't come OC'd, I believe the stock speeds that I had were 800/1200
Running it on a Z68 Extreme 3 Gen3 MB
i5 2500k at Stock @3.30 Ghz
22 and 23 inch monitors at 1920 x 1080
550W PSU
The main game that I play is World of Warcraft, I've noticed when i'm in and around major citys, for example Stormwind City, my fps seems capped at 23-24fps, I upgraded from a vapour-x 5770 and im sure my 5770 was generally performing better than the 7950.
When I leave major citys in WoW, my fps hasn't been past 110, i'd estimate around 40-50 fps in general out of citys, is this normal? should the card be performing better than currently?
WoW settings:
1920 x 1080
AA off/low
Shadows off/low
VSync disabled
High Settings
Current drivers 12.10 (have tried 12.6 too)
Cpu temps idle around 30, not been past 50 while in game.
Gpu temp idles at 52, have not noticed it being much higher while in game.
I've done some research on the card and have found others having fps issues in general not only with WoW but other games, they seem to figure out the issue eventually, none of which have helped me, and I am having slight lag in other games that I have tested.
I've done a slight overclock on the card to 950/1375 along with 20% power settings using CCC overdrive and have not noticed much of a difference in regards to fps.
Any help would be appreciated, thanks.
550W PSU
WoW settings:
1920 x 1080
AA off/low
Shadows off/low
VSync disabled
High Settings
